westend
Oct 27, 2017Explorer
I have never had trouble when I use the pink stuff. Now I'll be hitting the road in about 3 wks so I have tried blowing the lines out with the air compressor. Never done it this way before and I hope it doesn't bite me down the road. I took the strainer off and cleaned the screen and made sure there was no water.
As long as you have the pump and strainer drained, there shouldn't be an issue. Make sure, when blowing down the lines, that you open the toilet supply valve and outside shower if you have one.
A guy should still use the pink in the drains.
