bobndot
Oct 27, 2017Explorer III
westend wrote:I have never had trouble when I use the pink stuff. Now I'll be hitting the road in about 3 wks so I have tried blowing the lines out with the air compressor. Never done it this way before and I hope it doesn't bite me down the road. I took the strainer off and cleaned the screen and made sure there was no water.
As long as you have the pump and strainer drained, there shouldn't be an issue. Make sure, when blowing down the lines, that you open the toilet supply valve and outside shower if you have one.
A guy should still use the pink in the drains.
Good advice to do the toilet, that would be expensive . Blow air thru everything you can. Also the outside shower and black tank rinse if you have them.
In addition to using the air, if you use the pink stuff as added insurance, you could put it thru then blow it out . You don't have to leave the pink stuff in the RV. That offers less flushing of the system when/if you decide to use it. No pink stuff residue in the system.
