bsbeedub
Oct 27, 2017Explorer
Captain_Happy wrote:
If you want to educate yourself try this. First blow out all the water lines. If your trailer came with a winterizing kit attached to the water pump, pump some pink anti-freeze through the whole system, and don't forget the water value on the commode. And you'll see just how much more water is being pushed out of the lines. It might be a pain in rear, but it'll save you even more if a line or valve freezes and breaks. It may not got the cold in NC, but all it takes is one time. Now you can get a good nights sleep.
Captain, I’ve used this process since day one and I’m still surprised at the water that remains after what I feel is a pretty long purge with 40 PSI. I’m happy with the results.
