garyemunson
Oct 27, 2017Explorer II
Gets **** cold here in Reno. I use a compressor to blow everything out. I'll go around all the faucets 3-4 times until only air is coming out. Use the pink stuff for all the traps. Take the little pump strainer apart to make sure it's empty and run the pump for a few moments to purge the water from it. Never have a problem with freezing. We will camp year around so I probably do that dance a dozen times through the winter.
