J.Duncan wrote:
My dude, so many questions. Does the camper require an 8’ bed? How long is your flat bed? Do you have center of gravity issues? Is there a large space between your camper and your headache rack? Literally exactly what I want to do just Ford and Northern Lite.
Those were several issues I had to address.
The camper I have requires (at least) an 8 foot bed. Note I got a cab and chassis truck - which has a 9 foot bed. The rear axle is moved a foot further back away from the cab (than on a truck with an 8 foot bed.) Moving the axle back means the center of gravity of the TC will remain in front of the rear axle - where it belongs.
If I am correct, the Northern Lite 10'2 is designed for an 8' bed so it should work on any truck with a 8 foot or longer bed that can handle the weight. Make sure the weight of the truck + the weight of the TC + the weight of your new flat bed + weight of all your "stuff" (i.e. fishing gear, dogs, food, beer, etc) does not exceed the GVWR of the truck. Please do your homework first before buying your truck. I recently acquired a Ford 2011 F-450 that had only a 13,300 GVWR and was 1000 lbs over the GVWR with the Lance loaded (but that is a story for a different time)
Check and confirm how much room is under the cabover of the Northern Lite. I have heard that newer Ford cabs are taller than other trucks - but I dont have any written documentation to support that - just rumor.
If you get a cab and chassis model like I did, you will have 12" between the front of the bed / headache bar and the front of your camper. I temporarily put some 2x4's in there to keep the camper from walking forward on the bed, but I am looking at building a frame from aluminum that will keep the camper from walking forward along with providing space for another fresh water tank.
A note on tiedowns - the flatbed has a rail along the side. I used that in conjunction with Torklift "Original FastGun Turnbuckle .45- Polished S9527"
Before you load the camper on the truck, verify the truck will fit between the front jacks. You might need front jack extensions.
Thats about all I can think of at the moment. Let me know if you need any other information!
