The_Clubhouse's avatar
Mar 10, 2021
Now the water heater is leaking?
I am back home but trying to get my water lines working. I installed 2 new 1/2” valves. When I connected the first and closed it after running city water for a short while the water started draining out of the other drain, assuming hot water. I turned off the city and let the water stop draining then installed the 2nd 1/2” valve. I turned the city water back on and rather quickly noticed water coming out from the water heater area. Upon closer inspection I could see a stream shooting out from the cooler type insulation. I shut off the city water and opened both valves to drain the water. Not sure what if anything I did wrong. Any thoughts on what happened?
  • I am with billtex. Your post makes little sense. Where and why did you install valves? What "drain" was the water leaking from? It also appears you had water coming out of the "cooler type insulation". I have no idea what that means. I thought the water was leaking from the hot side. What cooler?
    Kind of a cryptic post. We need the story from the beginning...
    I’ll take a shot; is the pressure valve closed?
