jmtandem
Oct 29, 2013Explorer II
My truck has an Eton-Fuller 10 speed auto-shift, transmission. The "auto-shift" is a regular 10 speed manual transmission that has been equipped with a computer controlled shifter, this is what is known as a "three pedal" transmission, in that there is a throttle pedal, clutch pedal and brake pedal.
At 65 mph what rpm's are you turning and does the auto/manual trans auto shift for up hills or do you need to move a switch on the shifter to get an up or down shift w/o the clutch? For example, does it have a computer that skips shifts going up if the need is not there to use every gear? Or is the driver still the computer for shifting and when to shift?
44,066 PostsLatest Activity: Jul 25, 2018
