2oldman
Jul 28, 2018Explorer II
85 vs 87:
"Octane measures resistance to knocking, ergo, higher altitude means you can use lower octane. If your car runs fine on Regular (87) at sea level, it should run fine on Regular (85) at high altitudes. It's not an exact equivalence, but it's good enough for a car."
Ethanol:
"In terms of its octane rating, ethanol has a rating of 113. Fuels with a higher octane rating reduce engine knocking and perform better. ... When you mix 10 percent 113 octane ethanol with 85 octane gasoline it increases the octane two points to the normal 87 octane most consumers use."
Ethanol:
