ShinerBock
Jul 29, 2018Explorer
Lynnmor wrote:
I understand all that, I also know that knock sensors and related precautions are still utilized for protection from low octane fuel. If injection and turbo systems were capable of completely eliminating knock, we wouldn't even be having this discussion and Ford would say run whatever you want for fuel.
Ford does say to run whatever pump fuel you want that is 87 or higher, but they also say that 91 will add more performance to the engine.
I am not sure you understand how it works. The engine will run at the optimum timing until it detects knock. Then it will pull timing back to a point where it is not knocking thus determining power output. This is happening all the time while your engine is running and it is a constant back and forth depending on load, heat, and other variables.
So for example. Say you have 87 octane in your Ecoboost truck and you are towing a 10k trailer. The engine will be constantly adjusting timing to give you the most power it can on 87 octane without knocking. Lets say it can only give you 350 hp and no more without the engine having multiple knocking events per cycle.
Now lets say that all of the sudden 91 is in the tank and the knock sensors are not detecting any knock at the current timing of 350 hp so it advances it a little more increasing power output to say 360 hp. Remember, it is trying to run at optimal power levels so it advances timing a little more to 370 hp output if it does not detect knock at 360 hp. If it senses no knocking there then it will continue to advance timing as far as it can until knock is detected say 375 hp and then pull it back to a degree where there was not knock at 370 hp.
If you ever data logged the timing on the Ecoboost or any modern engine then you will notice that it is constantly adjusting timing multiple times a second. This is why engines like the 1st gen 3.5L Ecoboost had an advertised power rating of 365 hp on 87 octane and a non advertised power rating of 385 hp on 91 octane. It is not that it needs 91 to operate even when towing, but it will perform better if it does since 385 hp will pull a trailer better than 365 hp. Hence the reason why Ford recommends 91 IF you want better performance from the engine.
