Wikel's avatar
Wikel
Odd payload numbers on the 2017 F350 DRW vs. 2016 F350 DRW
I'm sure this has been covered but it's a nice bump up in payload. Good to see the military grade aluminum (whatever that means) is giving us more carrying capacity :)
2016 F-350 DRW
Reg Super Crew
137WB 158WB 172WB
F-350 DRW 4x2 14,000 6,840 6,340 6,870
F-350 DRW 4x4 14,000 NA NA 5,300
2017 F-350 DRW
Reg Super Crew
141WB 164WB 175WB
F-350 DRW 4x2 14,000 7,630 7,200 6,950
F-350 DRW 4x4 14,000 7,160 6,780 6,540
  • There are some things I really like about the new Fords, like that the fuel tanks are going to be 66 gals.
    The increased height, not so much.
  • Wikel wrote:
    ... Good to see the military grade aluminum (whatever that means) is giving us more carrying capacity ...
    If it is Military Grade, Ford should be able to provide the buyer a copy of the Specs on the Aluminum. I wonder what their response would bed if they were ask to provide the Spec Sheet.
    Wayne
  • Body gets lighter so of course load capacity goes up.
    It's all good.....until you need some body work done.
