mr_andyj
Jul 29, 2021Explorer
Since you will do this for one week and not again for the future...
I would get 100watt solar panel and a MPPT charge controller. Dont use communist Amazon, eBay has everything, but do what you want. It will cost about $80 for a 100 watt panel shipped and maybe $30 or so for a controller. 200 watts is better, but maybe 100 is enough for just your one battery.
If you want heavy power useage like a furnace or fans all night then consider adding another marine battery (better to add a true deep cycle 12 v battery, but youre just setting up for 1 week). If another battery then do go 200 watts solar.
You can put the solar panel in the closet and you will always have it as emergency or the next camping trip.
This will give you minimal use. No furnace, guessing in the summer you wont need a furnace?
You can run the LED lights and the water pump just fine. The fridge will draw nill DC on propane.
Careful running fans as they will draw down your battery at night, will be ok in the day time if on solar, but turn off later in the day so panels can send all juice to charge and not to run fans.
Marine batteries are not for RV camping, they are for boats. You can get by with one if it is in good shape though. If it rains and your solar cant charge then you can just crank the car. Bigger wires going from your car alternator (or car battery) to your camper batteries is more ideal as the trailer wiring is so small it can take longer to charge than the car's systems is able to charge it. Jumper cables would do in a pinch.
Other options like generators just get more and more expensive.
Without more info thats about all i have to add.
44,071 PostsLatest Activity: Aug 30, 2026
