Bedlam
Mar 07, 2018Moderator
80 PSI up front sounds like you are asking for a harsh ride from over inflated tires. I use the tire inflation tables based on actual weight to pressurize mine. I find the front changes very little whether loaded or empty and is never at the weight that would require that much capacity at maximum pressure. What's actual front axle weight 5000-5500 lbs?
44,056 PostsLatest Activity: Jan 12, 2020
