Me_Again
Mar 07, 2018Explorer III
Bedlam wrote:
80 PSI up front sounds like you are asking for a harsh ride from over inflated tires. I use the tire inflation tables based on actual weight to pressurize mine. I find the front changes very little whether loaded or empty and is never at the weight that would require that much capacity at maximum pressure. What's actual front axle weight 5000-5500 lbs?
Whoops, I missed RON post above.
LT235/70R17E at rated at 3085 lbs at 80 lbs inflation. Not that far over for the front axle. Cummins12V98 has had two 4th gen duallies and put a lot of miles on them and makes this recommendation that I parrot. Chris
44,056 PostsLatest Activity: Jan 12, 2020
