nohurry
Jun 29, 2013Explorer
Sounds like maybe the Luan was to glossy for the cement to grab. If you don't want to take it apart you'll just have to use it as is, and live with the appearance. If you put any screws in at all, I might put them through the side into the framework. This will keep it from falling. If you put any through the top you are inviting leaks, and it might look even worse. Also, try leaving it upside down and putting as much weight as you can all over inside and give it a week or so. Maybe the cement will grab. Good luck.
44,060 PostsLatest Activity: Mar 26, 2026
