FishOnOne
Aug 10, 2018Nomad
colliehauler wrote:FishOnOne wrote:Didn't Rotella T-6 reduce the Zinc and Phosphorus levels as well? If so how about the T-4 and T-5?
Problem with most responses here are oils of the past with API CI4 plus and CJ4 oils that had plenty of Zinc and Phosphorous anti wear additives. With the implementation of the current oil API CK4 Chevron (Delo) and ExxonMobil (Delvac) chose to reduce Zinc and Phosphorous levels in order to be in line with the gas engine API SN specification. Having said that I would avoid these two brands for now.
Rotella did not reduce the Zinc and Phosphorus levels in their T6 5W40 and their T4 and T5 engine oils. The reason is they decided to not make them dual rated for diesel and gas engines which IMO was a good decision.
44,068 PostsLatest Activity: Jun 01, 2026
