- Grit_dogNavigator IIIWhatever is on sale Every 4s engine I own runs on sale priced Dino 15-40. Except the wet clutch bikes get Rotella T6. Well, and I have put the spec 0w40 in the new car for the first couple oil changes , but it’s not necessary, just my current preference.
Maint interval is more important than brand of oil.
06 Cummins will live a healthy life on pretty much anything that says 15-40 on the jug. - mowermechExplorerI have used Chevron Delo 400 15W-40 in all my Cummins diesels over the years, both 12 valve and 24 valve, summer and winter. No problems to date.
My current truck has 409,000+ miles.
I use NAPA Gold oil and air filters (Wix)
I did find, a couple of years ago, that in the fall it pays to run the fuel tank well below half full, then fill with Winter Blend fuel. Near zero temps with summer fuel means you probably won't be going anywhere until it warms up! - fj12ryderExplorer IIII use Mobile Delvac 1300 in my 2001 Dodge Cummins. I tried Rotella TTT, but the numbers weren't as good as they were with Delvac according to Blackstone Labs, so I went back to Delvac and have lived happily ever after. I do change it every 5,000 miles or so, sometimes a little over, just depends. It's only about $12 per gallon so a little more frequent oil changes aren't that big of a deal. And usually a Wix filter, or Bosch, or Fleetguard.
- ppineExplorer IIIRotella T6 synthetic and Wix filters.
You can change filters and run the oil longer. Just add one quart of make up oil - Ron3rdExplorer IIII use the Delo 400 dino oil that's always on sale at Costco for $29 for 3 gallons. Meets all specifications. Synthetics have a benefit if you live in very cold weather. Doesn't get cold enough in So Cal.
Filters are Cummins/Fleetguard from Amazon. - SidecarFlipExplorer IIIIt has been discussed to death....lol
I use 5-40 Rotella T6 synthetic with a nano borate additive. Your choice may be different. So long as the oil meets the API and manufacturers certifications for your engine, you are good to go. Just adhere to the OEM recommended change intervals. - ScottGNomadDelo or Rotella and Fleetguard filters.
Also, the FLeetguard Airfilter out-flows the others (Wix, Fram, etc) hands down.
44,052 PostsLatest Activity: Nov 23, 2025
