sparky660
Jul 17, 2013Explorer
aruba5er wrote:
2011 and newer require the use of a synthetic blend or full syn. Do not use the old 15/40 You should be using the T6 synthetic. GM will not warrenty the motor with the use of plain old oil i;ve been told. And I find it very difficult to figure out the dipstick.No real "add oil or any other marks.
It is recommended but not required. As long as it meets the SAE guidelines you can use synthetic or dino oil without voiding your warranty.
As for the dipstick it stated in the owners manual that if you are in the cross hatch area you are good. If you are below the cross hatch at a quart. All of this is in your owners manual people, take the time to look it up if you are not 100% certain.
