Cummins12V98
Jul 19, 2013Explorer III
Charlie D. wrote:Cummins12V98 wrote:gmcsmoke wrote:Charlie D. wrote:
My 2013 owners manual says nothing about semi or full synthetic oil. It does state to use 15w40 CJ-4.
Your manual says to use 15w-40 zero and above which is dino oil. It also says to use 5w-40 below zero which is a synthetic oil
So you don't think there are any 15-40 Synthetic oils?
That is not what we said. A poster said;
2011 and newer require the use of a synthetic blend or full syn. Do not use the old 15/40 You should be using the T6 synthetic. GM will not warrenty the motor with the use of plain old oil i;ve been told."
Our response was that GM does not say that you must use a semi or full synthetic. Exception is 0 Deg or colder but that was not the topic we were referring to.
I am talking aboput what smoke said. re read.
