kearlms's avatar
kearlms
Oil Pressure Dropping to 0
I have a 1996 Chevy C3500 with the 454 in it. It has started having an issue with the oil pressure. When I first start the truck cold I have good pressure at about 60. I can drive it around and once it gets nice and warm the pressure will drop down to 0 if I stop and let it idle. I changed the oil and used 10w30 to see if the oil had lost its viscosity. It seemed to help but still is dropping. Sometimes at idle it drops to about 10 and other times back to 0. Any suggestions? Is my oil pump to blame or what?
  • I have that same problem in mine from 2005 with the speedometer and oil gauge...have heard there is a recall on the cables for these
  • Could be a few things. Low oil pressure
    I would try a 10W40 or 20W50 oil and see if that makes a difference first. If the engine was not using excessive oil, I would look to the pump or pressure relief valve after that.
  • It could be a sender failure. it could be a wiring to sender failure...it could be a mechanical failure
    Remove sender and put a known to be good mechanical gauge in it's place...then repeat how you were getting ZERO pressure...and check the mechanical gauge at that time
    you will immediately know if its electrical or me
    mechanical at this time
