ktmrfs
Oct 25, 2015Explorer III
wrgrs50s wrote:
Unless it's extreme high miles, I would suspect a faulty guage before an engine problem. Those gauges are notorious for acting up.
on the 2003-through at least 2006 the stepper motor that drives the guages has a tendency to go bad. By 100K miles, some small % of owners have one or more gauge that act erratic. On my 04.5, it was the spedo.
symptom is a "sticky" gauge, erratic gauge, slow to respond gauge. Anytime one doesn't act like you expect it should, I'd suspect a bad stepper motor on vehicles of that vintage.
Good news, is that there are sellers on ebay that will sell you a complete set of replacement stepper motors. It's actually pretty easy to replace them, along with ebay seller that will sell replacement lights for the gauges. As long as your in there, may as well replace all the stepper motors and bulbs. All you need is a small soldering iron. It's easy to remove the gauge cluster and get access to the bulbs and motors if you determine that is the cause of your problem. Some of the sellers will sell the parts along with detailed instructions.
The spedo, oil pressure are the two that commonly fail first since they get the most dial movement.
I've done mine along with several other folks kgauges. figure 15 minutes to remove the cluster, 15 minutes to disasemble, 30 minutes to replace all the stepper motors, another 15 minutes to replace all the bulbs, 15 minutes to reassemble, and 15 minutes to replace the cluster in the panel.
Then time for a cool one to admire your fully functioning cluster.
44,067 PostsLatest Activity: Jun 03, 2026
