LuckeyUs's avatar
LuckeyUs
Oil Pressure problem
We have a 2007 Chevy 2500 Diesel truck. Sometimes the Oil Pressure light will come on saying that the Oil Pressure is low, Stop Engine. Then the light quickly disappears. This has happened even when the oil has been changed recently (1,000 miles), & is now becoming a more persistent problem. Chevy never heard of this, so we're wondering if anyone else has had this trouble & what they did to fix it.
  • Change out the oil pressure sending unit.
    When did it start coming on? After oil change? Wrong oil filter?
  • Yea, any real mechanic should be able to do a pressire check for you. Most likely culpret is a bad sending unit. But bad oil pump is also a good possability.
  • Have the oil pressure checked with a reliable gauge, if it is low the engine may be spent.
