SoundGuy
Sep 20, 2016Explorer
Walaby wrote:
Do you have a heavy duty torque wrench that goes up to 250(ish)?
250 ft-lb torque wrench is inadequate. Here's the list of tool requirements from the Equal-i-zer installation instructions.
TOOLS NEEDED FOR INSTALLATION
The following tools will allow you to install the hitch properly:
1-1/8” Box-end wrench (Shank Bolts)
1-1/8” Socket wrench (Shank Bolts)
3/4” Box-end or socket wrench (Link Plates and L-brackets)
5/8” Socket or box-end wrench (Angle Set Bolt)
Measuring tape
Pencil
Torque wrench capable of 320 ft-lbs of torque. (Shank Bolts)
Torque wrench capable of 75 ft-lbs of torque. (Sway Bracket Assembly)
Recommended tools for installing the Hitch Ball:
1-7/8” Thin-wall socket (available from Progress Mfg. Inc.)
Torque Wrench capable of 430 ft-lbs of torque (or higher if hitch ball manufacturer specifies).
44,071 PostsLatest Activity: Sep 17, 2026
