93Cobra2771
Sep 22, 2016Explorer
Assuming your speeds are kept reasonable (50mph or less), I see no issue. Yes, you are over the 500# ball weight on the receiver (without WDH) and will have no sway control. Take your time, don't try to win any races, and MAKE SURE your trailer brakes are working prior to pulling out.
It will drop probably 2" in the rear, assuming the 625# dry weight is correct.
If you are mechanically inclined at ALL, do the WDH install yourself. It will most likely save you from having to redo the install the dealer does. Unfortunately, some dealers don't have the best track record when it comes to installing WDHs correctly.
