debtor
Mar 04, 2015Explorer
Okanagan 117DBL
Hello All: This is my first post ever. I have just purchased a 2008 117DBL and will drive to Fl. from ND to pick up (road trip yah). I have a 2011 3500 cab and chassis DRW, 6.7, manual 6sp, 4.10 ge...
debtor wrote:
Hello All:
This is my first post ever. I have just purchased a 2008 117DBL and will drive to Fl. from ND to pick up (road trip yah). I have a 2011 3500 cab and chassis DRW, 6.7, manual 6sp, 4.10 gears, flat bed. This weekend I will be lowering the bed and cutting out and putting in some shallow wheel wells for tire clearance. I grew up pulling trailers and in recent years have had a couple of 5th wheels. This is my first time with a slide in and need your advise. My truck has a payload capacity of 5210 lbs compared to a 3500 with a box on it @ 4680 lbs. The cab and chassis has a heavy straight frame and what appears to be a heavy factory suspension. In your opinions do I need to add airbags, and will it lean left when loaded? I would prefer to get home without adding air bags yet. Thank you all in advance, John
