debtor
Mar 04, 2015Explorer
Okanagan 117DBL
Hello All: This is my first post ever. I have just purchased a 2008 117DBL and will drive to Fl. from ND to pick up (road trip yah). I have a 2011 3500 cab and chassis DRW, 6.7, manual 6sp, 4.10 ge...
Reddog1 wrote:
I would make sure I had a rear anti-sway bar. As the name implies, it reduces sway. The larger the bar diameter, the less sway. I am not understanding "... will it lean left when loaded ...".
I am an airbag fan. However, I am not sure I would be overly concerned with picking up your TC without them. Worst case, is your headlights will aim a little high,. and if excessive a screwdriver will take care of that. Then when you get home you can decide if you want bags.
I will point out, the purpose of air bags is not to reduce sway, it is to lift the rear of the vehicle. They can help reduce sway, or if inflated improperly they can create sway.
