No..... HD hasn't been unlucky when we look around the net at rv and non rv trailering forums and on NHTSA tire complaints website. Very common in fact.
The OP has a small tandem axle TT at 4600 gvwr which is one reason he has good luck with those Loadstar ST tires. Around the net they have a typically bad rep for tread separations
This from Carlisle :
Time and the elements weaken a trailer tire.
** – 3 to 5 years is the average life expectancy of a trailer tire,regardless of mileage.
– It is estimated that in approximately three years, roughly one-third of a tire's strength is gone
– After three years, depending upon storage and conditions of usage, consider replacing trailer tires even if they have tread depth remaining.
– After five years, trailer tires should be replaced in all cases.**
I've never seen a ST tire makers website that says 5-7 year replacement time in the period others mentioned.
No doubt the new gen ST class tires introduced the last few years will last longer than the older maypops they replaced.
The OP dot date code will determine when its time for new rubber on the road.
