arkieguide wrote:
Did all the lights work before you changed them out ?
Take a simple 12 volt tester and check the power to the sockets.
Some time when working on these thing's a wire will come off a splice.
The socket terminals may be bent to far down to contact the lamp terminals. Good luck.:)
Volt meter reads 0 on all the lights (did not test the working one obviously) , the lights have never worked to my knowledge but then we never really tested things until last summer when i gott eh great deal on a boat and purchased a trolling motor, the rainy day made me experimental and I hooked up the battery to the trailer, found what was working what was not, thought burnt out lights, but now with the great deal on a solar panel kit (90$ for the whole kit and a solar charger etc) I figured it was worth it to try and get at least the two other lights in the line to work, I'd be happy if I could get the lights over the table to work so we could at least play at night without having the darkness overwhelm us!
So I'm thinking I may pull of just disconnect the old wiring, run a new wire along the top of my roof (inside) in a conduit and just reconnect the lights with a new wire, I am sure they would work, and if not I could purchase inexpensive set at the trailer shop to place and get to work. as I said I am pretty handy and not afraid to do the work if I get a firm idea of what to I need to do, I figure I could connect new wiring to the working light set and daisy chain them but only if that is the correct method to do it.
