steve-n-vicki wrote:
the fuse holder is available look up panel mount fuse holder
Inoticed some have different voltage? One at princess auto says 32v 20amp would that be adequate? The 20amp is what's currently plugging into that and it appears to be a simple enough job to unhook/reconnect it being only 2 wires I think I could handle doing the job myself.
As for the trickle charge, right now it's not in the budget as I would need 1 for each battery I just thought putting htem on the charger (for the time being) would be adequate since it's still recharging and letting it drain a bit.
I so far have this setup...
Eliminator Battery PackBattery I purchasedSolar Panel KitThis is the solar panel kit I have (I got it for cheaper as well)
I have another battery for the trolling motor as well that I could swap out in a pinch but that's the battery I plan to go with for the RV use. Any opinions? or did I just throw away my money? 8-)
