westend
Apr 28, 2015Explorer
TRy this: Go to one of the big box stores or a paint store and buy a gallon of Jasco prepaint conditioner. You will also need a garden sprayer or large spray bottle. Mix the solution to be used 50-50. Spray down your trailer with this mix and let it sit on the surface for 5 minutes. Scrub in and them rinse. You can then wash and wax the trailer with any good stuff like Marine products.
What you want to remove is the oxidization in the surface of the fiberglass or gel coat. Jasco is a good product for that. If it doesn't remove enough you can then go to more intensive treatments like rubbing compounds.
