CopilotCompanio
Nov 11, 2016Explorer
One upgrade possibility is to swap plain white fiberglass for this composite material designed to look like granite.
Front door of the showroom/office.
Prepare to sit in a camping chair while you choose your finishes. I thought it was appropriate for the occasion.
It's a full house on the roof.
The throne. Enough said. Unless you care to opine?
The bedspreads are messy because we'd given the beds a whirl.
This was, IMHO, the most fascinating discovery of the trip. Anybody know what it is? This funnel-looking thing (not the blue tube) is found multiple times on the bottom hull? It is... drumroll... a weep-hole. They're designed to shed any moisture which may accumulate inside the hull. So, while other manufacturers would like to hold us personally responsible for the fact that moisture accumulates, these guys accept it readily & plan for it. Different, right? Maybe not? I'm a newbie. Please set me straight?
All the metal parts you see are heavy-duty, high quality stuff. I think it is impossible to convey this with words and a picture. Seeing is believing.
The handles for the knife valves, as well as the valves themselves, are all fully insulated. You'll notice that even the door on this exterior panel is insulated?
The waste hose is stored within close proximity of the connection. In fact, you could drive with it connected, if you so desire.
