adamis's avatar
adamis
Nomad II
Jun 17, 2019
On-board Air Compressors
Since Pismo Beach is now a regular destination for me and airing down the tires is a requirement, I'm looking at options for an on-board Air System.
I've settled on a system by VIAIR with dual compressors plus an on board tank. It is a bit on the pricey side and might be more than I might use on a regular basis. However, with as many as 8 to 10 tires to fill (6 for the Dually plus 2 to 4 for a Trailer) I really want something that can handle these much volume without having to wait on a duty cycle.
Right now I like this kit:
Does anyone have experience with onboard air systems and care to share your thoughts?
  • otrfun wrote:
    adamis wrote:
    Thanks everyone for your comments. I'm leaning towards the following options:
    1. VIAIR Dual 485C with 2.5 Gallon Reserve Tank for $840.00. It flows 3.82CFM at 0 PSI and 2.09CFM at 100PSI.
    2. Extreme Air Magnum Kit for $950.00. It flows 6CFM at 0 PSI and 2.6CFM at 100PSI.
    3. Extreme Flow Belt Drive for $1500 (the compressor is only $425 but the mounting kit to attach to the engine is another $1100.00). It flows 8CFM at 100 PSI.
    Considering the costs, the ExtremeAir Magnum looks to be pretty close to the best balance between performance and cost. The belt drive solution looks spectacular but the mounting kit is way more expensive than I can justify for this project.
    The Extreme Flow at 8 CFM is going to fill those tires dramatically faster than the other two. Me, I'd spend the extra $500 for the Extreme Flow. You're already in for $900-$1000. What's another $500 to do it really right--lol!
    It is tempting but I was already splurging at the $1000 range. I think also I would like to keep the engine Bay as uncluttered as possible so I'm not paying a shop extra time to remove something in order to service the truck. It is still in the back of my mind as I haven't pulled the trigger just yet (I have a couple of weeks before I have to make a decision) so we shall see what might pop up till then.
  • rhagfo's avatar
    rhagfo
    Explorer III
    Well had a PacBrake air powered exhaust brake on our 2001 Ram 2500, got real use to having air where the truck was!
    Jump forward to the new 2016 Ram 3500 DRW with factory exhaust brake, NO Air!! :S
    Well hunted down a VIAIR system constant duty at 100 psi, and max pressure of 150 psi, with a 2.5 gallon tank. I chose to mount the tank and compressor inside the side panel of the bed on the passenger side.
    I managed to do this install with only drilling a couple small screw holes in the new truck.
    Bracket to support tank under bed, used bed mounting bolts, and two more unused 12mm-1.75 holes to attach.
    Tank in place and compressor mounting bracket in place, clamped to box frame.
    Engine bay air outlet.
    Air outlet in bed.
  • rhagfo's avatar
    rhagfo
    Explorer III
    BarryG20 wrote:
    Not sure anyone is against viar as much as they are enamored with 120v units, which if you have a big ol dp or whatever with storage space out the ying yang they make more sense. However for those of us who have limited space, want the convenience of having it all the time even when we aren’t hooked to our trailer (or as op no trailer but a tc) with no fuss no muss just use it as it is always ready to go no getting it out, plugging it in, hooking it up to a battery etc. viar makes some decent units and have some decent reviews. They aren’t the best but they seem to advertise the most and are probably the most heard of and certainly would work for the majority of people. The op has quite a chore going for whatever unit he ends up with as 8-10 tires going from 20 to 80 psi in a 32,33 inch tire is one heck of a lot of air
    X2
    OP is asking about ON BOARD AIR, not a carry around 120V pancake compressor, nor a pack around weak a$$ pack around 12 volt system. A good 12v on board compressor takes some power, mine can draw 20 amps. My air is ALWAYS with the TV.
    Currently I have a bunch of spare payload, but don't want to need a 120 Volt power source. be it generator or inverter. My VIAIR system with 2.5 gallon tank and 12 volt constant duty cycle at 100 psi.
  • Adamis: I run the Extreme Aire Magnum and can't say enough good things about the compressors and the customer service. If you need assistance you make one call and go right to the source. I have run my Magnum for over 6 years and not one failure and when they say 100 % duty cycle they mean it. Call and talk with George he is a wealth of information. I am in the process of putting together an Extreme Flow kit for new truck now!!
    Thanks for the feedback! I did like the ExtremeAir as it is one single pump versus the dual that the VIAIR required for similar air flow. It is a little more pricey but close enough for consideration.
  • I installed a viair with tank on a previous truck and was very happy with it. Pricey but convenient and easy to use. I always have a trailer at Oceano dunes so a generator and pancake compressor also has worked well. I don't have a need for air that often now so I use the less convenient pancake compressor as it serves use at home and on the road and with the trailer space is not an issue.
    On a side note they are having a meeting and vote in July that will probable result in closing about 30% of the Oceano Dunes riding area and decrease the amount of campers allowed by 30 - 40%.
