kerrlakeRoo
Dec 30, 2017Explorer
Cycling off and on is common on tankless systems.
These units need a minimum flow to turn the heater on, if the flow drops the heat turns off. Mixing hot and cold reduces the Hot flow just enough to shut the unit down.
Try barely opening the hot water at the bathroom sink while running the shower. Just a small steady stream will often give the unit sufficient flow.
44,066 PostsLatest Activity: Mar 14, 2015
