Golden_HVAC
Jun 14, 2015Explorer
3 years is a long time for oil to stay in the engine, even if it is not run very much. Yes moisture could be a problem, as condensation in the engine will land in the oil.
I would go ahead and change it, probably only going to be about 2 quarts of oil anyway. Problem seems to be reaching the oil drain point, and getting a funnel into that area to collect the oil. It might take a baking sheet pan, or something to get it out? That would be better than removing the entire generator - at least part way to get below the oil drain.
I would be putting in synthetic oil, as it will be durable for the next 5 years, or 150 hours of run time. . It will be less likely to absorb moisture from letting it sit.
Good luck,
Fred.
Good luck,
Fred.
44,066 PostsLatest Activity: Mar 14, 2015
