Dirtpig
Jun 14, 2015Explorer
oil drain bolt is easily accessible on the bottom of your Onan the way arctic fox installs it. Pull the drain bolt, drain it, add 1 L of oil (1qt) and your good to go. to check, u dont screw in, this is pretty much standard practice in all small engines as far as i know. Personally i use synthetic oil and change it every 2 years no matter how many hours on it. synthetic also makes it very slightly quieter. If you use regular dino oil i would change once a year.
44,066 PostsLatest Activity: Mar 14, 2015
