B_O__Plenty
Jul 17, 2015Explorer II
Are you sure the ground you parked on is level? Fuel weighs about 7-8 lbs. per gallon. If you have a full tank you could have as much as 250-300 lbs on the tank side of the truck. I wouldn't be concerned. Tire wear? Have the alignment checked at a GOOD shop with experienced help. Not the inexperienced guys you might find at a low buck operation. They can tell you why your tires are wearing unevenly.
B.O.
B.O.
