wowens79 wrote:
I’ve got one of the tires in my TT that is worn almost bald. The other 3 are fine. I’m guessing it is out of alignment/bent. Can this be fixed without replacing the axle??
It’s been 4 years for it to wear out. Should I just replace the tires for and go another 4 years. I’m probably gonna trade in the next year or so.
Easy fix for a big rig trailer repair shop.
If the wear is across the tread its most likely a toe in/toe out issue.
If the tires tread has worn on one side it can be a axle camber issue.
Easy fix for for a big rig shop as they simply bend the end of the axle tube back to specs.
