Old-Biscuit
Jun 28, 2019Explorer III
Suburban SW6D.....
1) DC Voltage goes to on/off switch from a FUSED source (DC Dist Panel)
2) From switch it goes to a DC Junction box on left side of tank from the rear----wire nuts used to connect wires ---check if loose)
3) From the DC Junction Box the wiring goes to the set of t-stats --- High temp first then down connecting wire to Normal Temp
**(High temp trips if normal temp fails----manual reset via the PUSH TO RESET cover above gas valve---right side is for the propane Red Wires)
(Left side for 120VAC ---yours will only have the one on right side)
4) From the t-stats DC goes to circuit board ---backside of tank or attached to cabinet wall
5) DC then goes from circuit board to Gas Valve AND spark Electrode
Follow the DC to switch/from switch/from t-stat etc
44,029 PostsLatest Activity: Jan 21, 2025
