bighatnohorse
Aug 13, 2014Explorer II
darsben wrote:
Some models of Onan generators exhibit this behavior when the low oil switch activates
SEE: http://www.flightsystems.com/pdf/onan-rv-troubleshooing-guide.pdf
Page 5 may give you your answer
A very common problem with many generators: faulty low-oil sensor switch
Typical example is generator will start but runs for just a few seconds.
Easy trouble shooting is to (check oil level first) short across the switch to bypass it.
If genny runs okay then you know that it's the switch.
