bobndot
May 04, 2017Explorer III
Check the Jayco Owners forum to see the real difference between the JayFlight vs Whitehawk . Axle capacity, size of tires, standard EQ. water tank size option, etc . The JayFlight is the upper, then compare that to the other. Research the frame that its built on .
I would buy any floorplan i like from a dealer with a reputation to stand behind it. The differences in brand quality can be a lot of hype especially if you get a lemon and the dealer and MFG won't stand behind you.
A good dealer can make any brand a better trailer at no cost to you while under warranty and often beyond.
44,071 PostsLatest Activity: Aug 30, 2026
