n0arp
Apr 16, 2021Explorer
ognend wrote:
People are having the same issues with the new Cummins trucks. In fact, RAM switched back to a CP3 pump. Duramaxes are having the same issues as well.
You edited the post after my intial reply and made this about a fuel pump. Yeah, so that leaves only Ford shipping CP4s -- which have received incremental year to year improvements, by the way. The majority of your whole argument against diesels is the fuel pump, which falls apart here. Duramax moved away from CP4 in 17, I think.
ognend wrote:
I think you are proving yourself what I am saying. You just spent $80K buying a "German" only to spend more thousands on crippling it back to a lesser fuel pump, to protect it from an expensive failure. How about the emissions systems failures? Plenty of those as well
You grossly overexaggerate the issues.
For the next couple replies, you can have your straws now.
ognend wrote:
However did we tow things back when the "legendary" and "indestructible" diesels didn't have exhaust brakes? ;)
Dangerously, at times. Or Pacbrake.
ognend wrote:
Point to an example of a 3/4 ton or 1-ton SRW where the tranny or the axle or whatever is "heavier duty" in a diesel than in an equivalent gasser.
On Ram, there are three different transmissions, three different transfer cases, and two different rear axles in use for 2019+MY. Don't know about Ford. Generally, diesel parts across the board are strengthened to deal with the additional torque.
