Jarlaxle
Apr 17, 2021Explorer II
jshupe wrote:ognend wrote:
Hmmm. An F-250 gasser and F-350 gasser (in the SRW version) will almost always be rated for more payload because the gas engine is lighter than the diesel so at least in "legal" ratings with in a particular GVWR it will have more payload. The 7.3L Godzilla gasser Ford comes with the same 10-sp tranny as the equivalent Powerstroke. As far as I am aware, the same axles etc, are in the gassers and diesels up to and including the 1 ton trucks. A lot of the time they get artificially de-rated (on paper) to fit a lesser class of truck. It would not make any sense for the manufacturer to use different axles on an equivalent F-250 or F-350 gasser/diesel trucks. In fact, the "new" 10-sp tranny used by 2020/2021 Ford gasser/diesel offerings is built by GM and there is a rumor of a 10sp 6.6L Chevy gasser for 2022....
You keep using Ford as an example.
I'll take your word on Ford. On Ram, there are three different transmissions, three different transfer cases, and two different rear axles in use for 2019+MY.
You can get the same Aisin transmission with the 6.4 Hemi that you can get with the Cummins.
