jmatthews
Apr 03, 2014Explorer
I almost forgot that Ours did not come with a TV. I purchased one from the local Walmart and installed with a wall mount. I found the studs and mounted. Little word of advise Make sure you buy shorter bolts for the assembly wall mount as the TT walls are not 2x4 like a house.
I mounted mine and put in two hooks and use a tie down strap while traveling to make sure it doesn't go flying.
Good luck
Good luck
