Thanks for all the info.
Just need to double check some dimensions to make sure the renogy panel will fit. If it does, think it and the rogue converter will be the way to go.
Hope to get the panel and controller ordered today. Only other thing to order will be the water tight connection to go through the side of the fridge vent. Everything else and I can get locally.
Last question, figuring on mounting the controller under my sink, so 8' to battery and 13' to a single 100W panel. What size wire would you suggest? Would 10Ga be about the right compromise between cost and loss?
