eric7soccer
Oct 01, 2018Explorer
Mickeyfan0805 wrote:
Both look like good layouts (although I will say that 8 or more will feel VERY tight in that amount of space). Based on what you stated, my comments would be as follows.
On weights, you may be able to stay within 6,500 pounds, or so, loaded - but it will take diligence. The 277 very well may be more like 5,800 (or more) before you even pull it off the lot. Add water and it will go even higher (closer to 6,100 with a full fresh tank). It will take vigilance to keep it in the 6,500 range. That said, there is no way you will be in the 650 range for the tongue weight. These are running at about 11.5% of weight, dry. Add in the weight of propane and you are closer to 12.5% (which is a good range for a tt hitch). Even if you keep the tt at 6,500, your tongue weight is likely to be 800 or higher.
As to floorplan, it depends on your style of camping. We love having an outdoor kitchen, and use it all the time. On these floorplans, however, you are trading an outdoor kitchen for bathroom accessibility when the slides are in. If you do mostly local/weekend stuff, that works. For us, however, we travel longer distances and would never want to be without access to those bathrooms while on the road. It's all about your style of camping.
Good luck!
thanks for your input i'm mainly looking to sleep 6 comfortably, and I think I like the idea of the outdoor kitchen and I can sacrifice the bathroom for when we stop to camp while driving that should not be an issue for us although for long trips with kids it would be nice.
