valhalla360
Sep 10, 2021Navigator
Thermoguy wrote:Bmach wrote:Thermoguy wrote:
I think I read on here that any ball lock can be bypassed, the best way to insure no once can steel it, use a thick chain and chain the 2 wheels together. Then it can't be moved because the wheels won't turn...
Remove the tires and replace. Now it can be moved. Very simple.
Or just use a battery operated cutting wheel.
Nothing is fool proof.
If someone has a cutting wheel and 2 extra tires with the right lug pattern, I think they should get the trailer and an award for being the most prepared. Many thefts are that of opportunity vs well planned out events... Just my thought. The person that originally posted did repossessions of RV's. Said that is the most difficult to reposes.
If the OP could lock it in his back yard, park a car in front of it, or otherwise store it in a safe place, would he have asked the question? I'm guessing it's at a storage lot and he is concerned someone could hook up and drive off with it. It the lot owner doesn't see a guy changing tires, due to a chain through them, then you might need to chose a different lot...
Having extra tires is pretty unlikely unless it's some sort of professional job.
A battery powered cut off wheel...$50 and 30 seconds to cut thru a chain. Some guy who works in the trades likely has one already.
44,057 PostsLatest Activity: Mar 12, 2026
