gbw's avatar
gbw
Opinions on my dilema - newer trucks SRW vs DRW
I likely know the answer here...
Current truck has 350,000kms. Engine is pretty good but it has 200,000kms on the 2nd trans, oil pan leak, small electrical gremlins, rusting etc. Its getting tired. The wife has given me a green light for something newer.
I'm looking at 2012+ GM/Chevy and 2013+ Rams. My budget set but I can't drop $100k CAD on a new rig, so it'll likely be a 2012-2017 range. I'm leaning heavily to diesel on both rigs, my predominant travel is into the Rockies to the West.
My EC850 is kind of portly and weighing in around 4400lbs loaded up with kids supplies, water and gear. A couple trips a year, I tow a ~4000lbs ski boat. The camper is a shortbox model.
So here's my issue. Do I go for a SRW shortbox Ram? Reuse my heavy 19.5" tires? If I go GM, I'll need new 19.5" rim or I'll be just right to the tire max again. I will need winter tires as the truck too, it would be our highway travel vehicle. I do have a beater car for work commuting and errands. Up here, SRW trucks are SOOOO much more prevalent than DRW and a fair bit cheaper.
If I go DRW, I'll have to contend with the 1ft gap between the rear of the cab and front of the camper. I won't need to mess around with tires. I'd still need winter tires but the bonus would also be that I can use the camper with those same winter tires for ski trips.
How is the unladen ride of a DRW with aired down tires vs a SRW with aired down tires. Yes, I get its rough. I've had a 3500 for 10 years. Is the DRW much worse?
Opinions? the right solution is likely DRW. I've had campers for years, so I'm not new to driving with them or hauling heavy. Don't care about GVRW. I realize there is the megacab dually. I could go that way but up here, they command a mega-premium, so much more than a regular dually.
  • It is not a law if you can pay extra fee and have it changed?
  • mkirsch wrote:
    Grit dog wrote:
    Almost mutually exclusive unless you can't sleep at night if you're exceeding the door tag...
    He's in Alberta so the door tag might be law.
    Now if you can get Kayteg to believe that, you will have accomplished something notable!
    Alberta is pretty relaxed about the door tag. As long as you don't look overloaded, drive like an idiot, you're fine. Host Mammoth on a 1/2 ton? yeah, you're getting pulled over.
    BC gets a little more up in arms about tags but again, I've also just been waived through as I my rig looks alright and good condition.
    Sorry the replies got a bit chippy. It's one of those topics. :) And to me there's no problem bringing it up fresh as there may be new people with fresh perspectives as apposed to the old threads that always break out into squabbles. If folks don't like seeing it rehashed, then they can choose not to click on it.
    I agree with you that, up here anyway, as long as your rig looks good as in how it looks when loaded, you probably aren't going to get a second look. Perhaps due to different policing ideals then down south.
    I'm going dually with the new truck. I just think overall, it's going to handle and be safer. And you haven't got to mess with add-ons so much. And those add-ons, up here, can be hard to find and extra expensive as apposed to below us. :)
    If you're sure your camper will work on a long bed (CG at or in front of the axle) with a spacer, then go for it. If not, then go short. Don't know about AB, but out here in BC, SB seem to be mostly what you see. I'm going with new F350 CC/DRW/LB/7.3 gas as mostly the used market around me is SB and Diesel and SRW.
    Perhaps some savings could be had going with an AT tire so you don't need winters. But you know your local conditions best, so just a thought. I've got AT's on my SRW and in 4wd low, I can crawl up and down my steep, 1/4 km long drive with a foot and a half of snow no problem. I'll be going AT's on the new dually as well. And yes, opinions on duallies in the snow will be squabbled about for and against as well..... :D
    Good luck with the search! Hope you're not getting the smoke from the fires down south. It's back here again today. Ugh....
