BarkoffExplorerMar 14, 2015Opinions on PSISo I decided to go with to go with the Vision 7.5 Heavy Hauler and the Hercules 19.5 265's all around, so what would you advise running them at? They are rated to 123 psi max, but I'm pretty sure I...Show More
mbloofExplorerMar 15, 2015I think the minimum PSI for my Toyo 265/70 608Z's is 80PSI. I've been running that in the front and 90-95 in the rear.Each tire manufacturer and model is different. Please don't assume that the load charts are in any way "universal".Both the front and rear axles on my F250HD stuck out to much for the 'standard' covers so they had to order the deeper set for my truck.
Related Contenttire psiPSIOpinions on a camper that's been sitting for 2+ years?PSI rating variablesWhat PSI for tires?
