Barkoff
Mar 14, 2015Explorer
Opinions on PSI
So I decided to go with to go with the Vision 7.5 Heavy Hauler and the Hercules 19.5 265's all around, so what would you advise running them at? They are rated to 123 psi max, but I'm pretty sure I...
Barkoff wrote:
So you concentrated the heat towards the outer portion of the cap away from the wheel, correct? Did you apply the head while the cap was in place, and then apply pressure, or did you heat it up without it being mounted? I'm wondering how quick you have to be once you get it heated up.
Am I seeing burns in the chrome finish or just reflection?
Thanks again
