John_H
May 10, 2014Explorer
Hello Curly,
If you do not have one of the built-in black water flush system. I suggest you buy one of the black tank cleaning wands with the spinning brass spraying tips. That fastens to one of the larger diameter (not the white drinking water type) water hoses that you intern stick down the toilet from the top side while holding open the toilet valve, and using a repeated up and down motion flush the inside of your tank thoroughly. I lower mine clear to the bottom until it stops spinning, then lift a tad until it starts. This gets the bottom clean. If at the same time you buy one of the clear elbows fastened at the exit of you tank, someone out side can tell you how you are doing at the same time tell you when the water is finally running clear and on into the campground drain..I personally am sold on these wands, flush system or not. Working dilgently this will clean the probs for your indicator.
