brulaz
Aug 05, 2014Explorer
AndrewM wrote:brulaz wrote:
Apparently not.
The GVWRs are reduced as well so that lighter weight components can be used. For example, I understand that now the HD Payload option uses a 6 lug 4050# axle, not the 7 lug 4800# axle.
So HD Payload option still gives you increased payload, but depending upon how the weight savings are distributed between front and rear axles, it may be that the rear GAWR is now more of a limiting factor with HD Payload. We'll see.
Interesting. Where did you hear this? Haven't seen anything over at the F150 forums.
Somewhere in the discussion here: 2015 Order guide link
Page 38 of the guide has some GVWR and payloads.
Then somebody noted that the HD Payload wheel on p 23 has only 6 lugs.
There are no GAWRs in that guide. Just the 9.75" gear set for the HD Payload trucks. Guess we are just assuming that is the 4050# GAWR. Maybe 3500GAWR for non-HD Payload?
EDIT: the 2.7L EB has its own HD Payload package with the 9.75" gear set too. That will be an interesting truck.
